vehicle's speed sensor
Old Feb 12, 2005 | 02:21 AM
chrisuscga01's Avatar
chrisuscga01
Default vehicle's speed sensor
any one know where this is located and how to tap into it for installing a navigation system?
Old Feb 14, 2005 | 09:06 PM
billapex's Avatar
billapex
Default RE: vehicle's speed sensor
I suppose it's on the side of the transmission somewhere. That's where it is on most cars. However, do GPS units, such as the ones from Garmin, use the VSS? I was under the impression that they just plugged into a power source/lighter (plug-n-pray?).
Old Feb 14, 2005 | 10:46 PM
chrisuscga01
The headunit gps units now adays use the VSS for tracking purposes incase you loose a fix on the gps satellite. It keeps you on track until you can reaquire a signal
Old Feb 15, 2005 | 03:59 AM
dodgemech's Avatar
dodgemech
The LX uses the ABS module to calculate VSS. I would not recommend splicing in to ANY wiring that is on the CAN.
There is a reason the factory NAV system costs more than the generic systems.
