Dodge MagnumThe Dodge Magnum, the wagon that made wagons cool. The unique look of the Dodge Magnum makes any trim level, from SE to SRT-8, an absolute head turner.
Has anyone change sparkplugs on a sxt 3.5. Do I need to replace intake gaskets? Can it be done in a few hours. If so are their any problums I may run into. Thanks
the stock plugs are good for 100,000 miles. you have to remove the upper plenum of the intake. no gasket needed. the upper half is o-ringed. it is not an easy job. you have to remove a lot of things like the EGR tube and more to remove the upper plenum.
I repoed a 2006 Magnum SXT so I just picked up a Haynes Manual so I hope I can do some of the maintenance. Not sure about the Timming belt/waterpump. but Ill read up on it.
