3.5L Thermostat and PCV valve
Does anyone know the location of the thermostat and PCV valve on the 3.5L engine?
I'd like to change these as part of my routine maintenance. Will be doing a coolant flush and I'd like to change out the thermostat.
Thank you.
Thank you.
I found them today during a coolant flsuh & fill;
PCV valve - located on the passenger side of the engine, near the back, under the plastic intake plenum. A black hose is attached to it with "PCV" printed on it
Thermostat - on the driver's side of the engine, where the lower rad hose connects to the side of the engine. The best access to it is by removing the engine coolant reservoir. Don't forget to disconnect the power steering fluid reservoir from the coolant reservoir.
