REAR WILWOOD BRAKE INSTALLED PHOTOS
Old Apr 9, 2005 | 10:01 PM
armadillo's Avatar
armadillo
Default REAR WILWOOD BRAKE INSTALLED PHOTOS
Well,Todd at TCE Performance has been working on the rear kit for the Magnums and 300cto go with the Wilwood kit developed with the 6 piston caliper. It is done, and the rear is installed on my Magnum. Feel, is great, with a change from the stock braking ratio of 75% front and 25% to a more balanced number (more rear brake than stock) the car seems to just squat and stop, a big reduction in front nose dive. Stops are even and sure. Here are photos of the installed product. The red caliper to match the front is not available, I did them myself (power coated red and hand painted white lettering) (I can do this through Todd at TCE if you want a set in red to match the front) PM me for details.
Old Apr 10, 2005 | 12:18 AM
grinner's Avatar
grinner
Default RE: REAR WILWOOD BRAKE INSTALLED PHOTOS
awesome.
your car freakin rocks, man.
Old Apr 10, 2005 | 12:24 AM
maneval69's Avatar
maneval69
armadillo
Have you tested the traction control?
I've noticed that the stock brakes (on my RT) can not keep both tires spinning if you are turning with a lot of weight shift to one side. The brake on the inside wheel is not strong enough to compensate for the traction difference.
If these brakes have better grip they may not eliminate the problem but could improve the Donut factor.
Old Apr 10, 2005 | 12:52 AM
armadillo's Avatar
armadillo
ORIGINAL: maneval69
armadillo
Haven't tried side spin, straight line only so far, but it should be better, I'll check it out in a few days.
Old Apr 10, 2005 | 03:14 PM
MagnumRT's Avatar
MagnumRT
Great brakes and good looks also, dare I ask what it cost you?
Bob
Old Apr 10, 2005 | 04:45 PM
grinner's Avatar
grinner
you can get this set up for just over 2k, I believe.
That right, dillo?
Old Apr 11, 2005 | 02:55 PM
armadillo's Avatar
armadillo
The kits for both front and rear - calipers and all hardware pads etc is $2000 in black, red will cost about $300 more.
Old Apr 14, 2005 | 12:47 PM
Pentagon Magnum's Avatar
Pentagon Magnum
Dill, those brakes look sweet. I'd also like to know how they work with the traction control, who installed them and the cost of installation (if you don't mind).
Gotta like the name Todd and TCE Performance...my name is Todd and my initials are TCE. Does he have a website and what other performance options does he offer?
Old Apr 19, 2005 | 05:47 PM
armadillo's Avatar
armadillo
ORIGINAL: Pentagon Magnum
The brake are available from TCE the website is http://www.tceperformanceproducts.com/
If you call Todd will answer the phone, because mine was the first install, Todd and I worked for a bit getting the parts right. I didn't pay for install, it isn't hard though and Todd puts everything you need in the package, along with good directions. They work great, everything is seamless and traction control braking is great, greatly reduced nose dive, just squats and stops.
