07 sxt
Old May 26, 2010 | 12:30 AM
andylaiphoto's Avatar
andylaiphoto
Default 07 SXT Light Housing
Just got home from the dealership. Picked up an '07 SXT. I noticed that there is moisture in some of the lights. There's buildup inside of the housing. Is this something that is repairable or do you need to replace the whole housing?
Old Aug 3, 2010 | 11:53 AM
Curt Bradbury's Avatar
Curt Bradbury
I took my tlt off because after a large downpour I noticed water in the tlt. It wont get out by itself. I wadded up paper towels and placed this in the bright sunloght for a few hours. Most of the water has evaporated. But it will come back again. So I have epoxy from my aircraft building and mixed up a healthy solution of that thick stuff and placed it in the seam around the tlt. I am expecting this to end the problem of water gettin' in. On assembly at the factory, these are not tested and if there is insufficient glue applied during assembly water will find its way in. Gooed luck. Curt
Old Aug 4, 2010 | 01:39 PM
andylaiphoto
Thanks Curt.
