06 driver side window switches?
Hello - 1st time poster here, so thanks for taking a look.
So to make a short story long - I bought an 06 dodge magnum hemi.
Nice car and I feel in love with it the first time I drove it but didnt inspect the inside of the car as well as I should have. Well I found bits of broken glass all over the place. Looks like the car was broken into. So the other day I go to open the passanger side window from the driver side (using the switch) and it wouldnt work. I looked under the button and sure enough ther was glass under it. I lifted the switch but couldnt get my finger in to get the glass out so I blew at it. This coused the glass to go right down into the switch. Now I need to take the switch out to remove the bits of glass. How do I remove the switch. Do I need to remove the door panel. Thanks to every one that can help me out.
Yes you have to remove the door panel. I believe there are 5 screws (4 ont the bottom and one near each handle) and 3 push pin clips (at the front) that hold the panel on. There are also some alignment clips behind the panel.
