Lugnut's on these cars
Old Oct 31, 2010 | 12:02 PM
Wile C's Avatar
Wile C
Default Lugnut's on these cars
Apparently MOPAR or the German side of things, got cheap on the lug nuts for the RT's atleast, and the caps they put on them change in size actually get wider requiring a different size socket to remove them over time. The word is that they start off as 22 mm and then depending on how they were treated go to a 22.5 mm size socket rendering the lug wrench we get with the cars useless if needed. I went to Advance Auto and bought a set of aftermarket lugnuts to replace the oem and they werent the correct depth I was told by my mechanic. Anyone know the right size or what I should get to replace the stock lug nuts? I dont' want a situation to come up on the side of the road and not be able to change a tire. I can't believe how cheap DC got with this..you pay 35k for a car and they skimp on the lug nuts..go figure. Just like the alloy coming off my rims..pretty shabby quality in these things. 33k on the car.
Old Nov 22, 2010 | 12:01 AM
46FD04's Avatar
46FD04
Same problem with my '07 SXT.
Very crappy lug nuts, caps loosened, expanded with corrosion, needed a hammer to get the tire wrench on them, AWFUL!
I replaced them with Gorilla Lug Nuts, solid stainless steel, no caps.
My size is 14mm x 1.50 Acorn
Old Dec 23, 2010 | 04:25 PM
cpmgrp's Avatar
cpmgrp
New Member
Happened to me while getting tires. One cap popped off the nut and freaked out the tech. It's just the cap. Official advice: just crimp the cap back on (adhesive optional) and tap with a brass or rubber hammer.
Old Dec 28, 2010 | 01:47 PM
japhy's Avatar
japhy
I have had two different garages strip or cross thread the lug nuts during tire rotations on my 05 magnum (once by a dealer). The last time the nut stripped and had to be drilled out to get it off. In my situation, I believe it is a mix of sloppy mechanics and poor materials.
Old Jan 3, 2011 | 02:45 PM
Ramdit's Avatar
Ramdit
The lug nuts are 21mm. The problem is the people use the incorrect size socket and bugger up the covers.
Old Jan 3, 2011 | 07:11 PM
honu's Avatar
honu
Use an icepick and needlenose pliers to rmove the "stainless" covers. Use a smaller socket to remove the lugs and throw them as far as you can into the largest body of water you can find.
Lot of guys are using the Gorilla lugs... if you decide to use them, just make sure to get the ones with the proper angle on the seat.
