Dash light and needle going crazy
Old Nov 8, 2010 | 10:50 AM
mballard34's Avatar
mballard34
Default Dash light and needle going crazy
Hi everybody i am back with another problem
it happend 2 time in 2 weeks.
after about a 25 min ride going slow in the traffic, the dash light are going on and off like crazy, belt seat light and all the other lights you can imagine are going on and off plus the fuel and rmp needle are going down and up like crazy, but the car still ride good when happen no surge
i had to shut off the car to get some light to clear, no engine code.
help thanks
Mike
Old Nov 12, 2010 | 02:51 AM
Stovy's Avatar
Stovy
I'm not fimlar with the Magnum s . But perhaps try resetting the cpu , or disconnecting and resetting the battery and check your fuses that connect to your wire harness and then go from there. If it still happening and u can't do ur own , try to take it a local trusted shop .
Old Nov 13, 2010 | 11:10 AM
03MopaRamman's Avatar
03MopaRamman
Weird!! Agree, definately do a reset! Good Luck.
Old Nov 30, 2010 | 11:09 AM
mballard34's Avatar
mballard34
Angry
did the reset sorry no good
when to the dealer 89$ scan + extra time
Total 200$ later nothing same problem damm
he clean some ground on PCM and some connector, did not have any problem for 3 days but came back
so i wait until it completly fail
oh yea fan heater is going on and off also when the problem occur
(winter here)
Mike
Old Dec 16, 2010 | 06:32 PM
NJ1's Avatar
NJ1
Default Gages gone crazzy
I have the exact same problem with my Magnum R/T after 25 min of slow driving the lights first shut off then all the icons in the cluster comes on but when driving on highway never happened yet but for now car runs and did not stop what is this ? anybody have resolved this kind of problem?
Old Dec 17, 2010 | 11:49 PM
mballard34's Avatar
mballard34
We have the exact same problem, if you find it before me please share, so far it cost me 200$ with no result
M
thanks
Old Jul 25, 2012 | 09:03 PM
cablue's Avatar
cablue
Default same electrical problem
did anyone ever find out the solution
Old Jul 27, 2012 | 11:51 AM
ALLDATAdiyINFO's Avatar
ALLDATAdiyINFO
Former Vendor
Here at Alldatadiy.com, we do have symptom related information along with repair information. DTC are also in our database. Good Luck to you all with that issue.
Old Jul 29, 2012 | 12:11 AM
jaywan's Avatar
jaywan
help thanks
Mike
had the same problem and the dealer had no clue, I changed the headlight switch and have not had any problem since.
Old Jul 29, 2012 | 12:15 AM
jaywan's Avatar
jaywan
The headlight switch is tied to all of the dash lights, the dealer will tell you it's the wiring hornes but it's not, plugged in a new switch and all the flashing went away.
