Help Battery Disconnect Question
Old Jun 20, 2005 | 05:00 AM
magrt's Avatar
magrt
Default RE: Help Battery Disconnect Question
i have also disconected the battery and every thing work when reconected.
Old Jun 20, 2005 | 11:44 AM
chrisuscga01's Avatar
chrisuscga01
ORIGINAL: dodgemech
ORIGINAL: strippedhemi
I unhooked my cables for about 5 mins to connect my trailer wiring harness and the only thing I had to reset was the clock time and station presets. I have a fully loaded RT.
No, you are supposed to recalibrate the windows, the sunroof, and the steering sensor.
Dodgemech How do you recal the sunroof? Thanks
Old Jun 20, 2005 | 06:59 PM
LtlDad's Avatar
LtlDad
As taken from the Service Manual:
SUNROOF POSITION CALIBRATION
Press the power sunroof switch (Open, Closed, and Vent). If no movement occurs when either the open switch or
closed switch is pressed, but the system does move when the vent button is pressed and held, the system is not
calibrated. Perform the following procedure to position calibrate the power sunroof system.
1. Turn the ignition to the RUN position.
2. Press the vent button on the power sunroof switch and hold until the sunroof glass panel has moved to the full
vent position and the motor movement has stopped for at least 1 second.
3. Press the close switch on the power sunroof switch and hold for a moment (at least 100ms) and release. The
sunroof glass panel should continue travel to the full close position. If the sunroof glass panel does not return to
the full close position, refer to the appropriate diagnostic information for full system diagnosis.
4. Verify proper system operation.
