check engine light
Old Aug 25, 2011 | 07:49 PM
kawahni's Avatar
kawahni
Cool check engine light
05 magnum 3.5L rear wheel drive, problem; miss, stalls engine light is on [ banks 1 & 2 running lean. things I've done; replaced plugs, and intake seals checked for any kind of leak reset light. now car stalls and light is back on. reset light and travel on the hwy mileage is approx.390 miles per tank no light around town with in 2 miles light comes on and 260 miles per tank, same code. just broke down and replaced the EGR valve. the miss I beleave is in the peddle, very touchy, can this be tested before replacement, they are not cheep. out of ideas on the car. Thanks for the Help.
p.s. hit a dear a couple year back, 3 point buck at 55 mph and NO air bag the light came on. dodge says this is normal didn,t hit the dear hard enough but did cost 4800.00 in repairs, good thing this car has great brakes. check your wiring the bumper cut the harness on impact thought this would trigger when cut , guess not.
Old Sep 7, 2011 | 03:35 PM
kawahni's Avatar
kawahni
Default Egr
replaced EGR and no change engine light still on
