07 Magnum rear wiper blade
Old Sep 18, 2011 | 04:00 PM
jafo69's Avatar
jafo69
Default 07 Magnum rear wiper blade
I have had my Magnum almost 5 months and need to replace the rear wiper blade. I have checked with all the parts stores and no one has a listing on it and I have never seen a wiper blade mounted like this is mounted. Any idea on how to replace the rear wiper blade??
Old Sep 18, 2011 | 08:28 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Should just slide on/off like the fronts, just shorter. I think it's a 10" if I remember. Just not a lot of stores carry the rear blades because they are not hot sellers.
Unless you have some custom mechanics done to it, not sure then. Post a pic if you want to make sure, but like I said, it should just slide right on/off like the front blades.
Old Sep 19, 2011 | 10:31 AM
jafo69's Avatar
jafo69
The design for the 07 is different than the previous model years. It doesn't slide off like the front. I also tried ANCO and TRICO and they do not offer a listing for it.
Old Sep 21, 2011 | 05:51 PM
Silver bullit's Avatar
Silver bullit
I own an 05 and i to am looking to replace the rear blade...
Old Sep 22, 2011 | 12:26 PM
jafo69's Avatar
jafo69
Silver bullit....if yours is like mine, the blade is a dealer only item. runs about $17.00 but i couldn't figure out how top change the whole blade so i changed out the rubber. if you get an ANCO wiper refill 21" long, you can make 2 replacement rubber blades out of it which is what i am going to do.
Old Sep 22, 2011 | 07:51 PM
Silver bullit
cool ill head over to a shop that sells anco blades....Thats a gtood idea to buy a longer wiper and cut it in half ...
Old Sep 10, 2012 | 09:55 AM
jafo69's Avatar
jafo69
Default Update
The ANCO 31-21 blade did not work for me. I went to the NAPA Auto Parts store and got part number 60-021-1 wiper blade and it appears to work. The ANCO was too narrow. If you get the 60-021-1 from NAPA you can get 2 refills out of it (cut to fit) and just throw the metal frame away. Or if you are lucky enough to find a NAPA store that still sells refills in store, then just get a refill for the 60-021-1.
Old Apr 4, 2015 | 06:19 PM
ronpbeck's Avatar
ronpbeck
I bought one from the dealer for my 06 and ended up breaking the old one off. Was shot anyway!
