Wheels Questions 20" 22"
Old Jul 27, 2005 | 12:05 PM
mjunda's Avatar
mjunda
Default Wheels Questions 20" 22"
THose of you with aftermarket wheels, can you tell me if the ESP has issues with your new wheels and tire combs? If so how did you fix the issue? I have heard it some people say if flashes a lot when you swith wheels and tires bigger than the stock height.
If no esp issues, I'm sure your speedo is off right?
Is there anything I else I should be concern with new 20" or 22" wheels?
Sorry for all the ? newbie here.
Thanks,
Mike
Old Jul 27, 2005 | 12:32 PM
jy211's Avatar
jy211
Default RE: Wheels Questions 20" 22"
I have 22's...esp doesn't flash or anything like that...I can still smoke the tires easily in drive.....not 100% sure on my speedo..I think it's right...never really bothered checking...
Old Jul 27, 2005 | 12:50 PM
stboden's Avatar
stboden
I've had no problems with my 20's. I drive with the ESP off most of the time, but when I do have it on I've had no problems. You can use this site to check speedo.
http://www.csgnetwork.com/tireinfo4calc.html
There was a chart somewhere in the forums with all the proper sizes up to 22's. I could not find it with a search though.
Old Jul 27, 2005 | 05:25 PM
AJ_Gil's Avatar
AJ_Gil
I'm not sure about Magnums but my wifes PT Cruiser allows the tech to input the correct tire size right into the tranny control module.
It takes 3 minutes tops.
