Trailer Harness
Old Nov 24, 2011 | 05:18 PM
Silver bullit's Avatar
Silver bullit
Default Trailer Harness
I am looking for a haness for the magnum. the dealer has one but at 175.00 per is nuts. uhual well do they work well...Thanks
Old Nov 25, 2011 | 09:19 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Yes, but when something unexpected happens and that cheapo harness doesn't provide adequate circuit protection for your Front Control Module/TIPM, you'll think 175 bucks is very cheap....and I can promise you the unexpected WILL happen. It always does. Whoever puts it in make sure they teather the existing wiring harness so it doesn't fall down on the tailpipe.
Old Dec 7, 2011 | 09:50 AM
Budsned's Avatar
Budsned
New Member
Default I put one on my Maggie
I bought one online - easy to find - just google for it. It was custom fit - all the plugs worked, etc. but installation was a bit of a pain. As you prob know, the Mag has separate brake and turn signals, so, to convert that to a cheapo trailer which use the same bulb and filament, a relay is needed - which is the heart of the kit. It worked fine but only lasted a year before the relay quit and the lights no longer worked. I ended up just hard wiring it so that the brake lights worked but the trailer doesn't have turn signals. I might get a ticket some day...
Old Dec 8, 2011 | 09:29 PM
Silver bullit
I bought a oem unit a few years ago and now i will be buying another i wonder do they sell just the relay...
Old May 29, 2012 | 12:08 PM
anton188's Avatar
anton188
I bought a kit at my local NAPA store and painstakingly installed it in a Saturday afternoon. It has worked flawlessly for 2 years now. I would also take TNtech's advise about teathering the harness. I secured all the wiring and mounted a small clip that holds the wiring connector to the 'hidden hitch' frame when not it use so it doesn't hang down & get snagged/dragged.
