Timing Belt 2006 Magnum
Old Feb 27, 2012 | 04:42 AM
DNICE's Avatar
DNICE
Default Timing Belt 2006 Magnum
Need help! I'm at 100,000 miles and need to replace my timing belt and water pump on my 2006 Dodge Magnum 3.5L v6 SXt. How hard of a job is it to do? The chilton/ haynes manual is very vague. Thanks for any advice
Old Feb 27, 2012 | 11:37 PM
steak59's Avatar
steak59
it is fairly easy. You just remove the Radiator Fan, belt, and timing belt cover, there's your timing belt and water pump.
Old Feb 28, 2012 | 01:39 AM
DNICE's Avatar
DNICE
Ok thanks. I thought it would be a fairly hard job.
Old Mar 27, 2012 | 06:57 PM
rustyb06770's Avatar
rustyb06770
Talking 05 Magnum 3.5L SXT - timing belt 100k service
I was wondering if doing the timing belt would be a hard job to do and found a post for an 06 SXT with the 3.5. It should be the same. Doesn't sound to difficult to get at. Thanks for the previous posts !!! At 100k all i've had to do is a couple front end parts, egr valve and the pink thingy in the shifter (maybe $300). Not bad for 100k
