My Intake Test Fourth (and final) Phase
Old Aug 19, 2005 | 10:16 PM
magnuman's Avatar
magnuman
Default My Intake Test Fourth (and final) Phase
These intake tests have taken several months to complete, but here are my results from this last phase (Phase 4), as well as my opinions (for what they're worth), and observations. I'll summarize by including results from each phase so you can see, in a nut shell, how the various configurations worked. Also, the highway driving for this phase was two long trips of about 1500 miles each. To see how and why I did these tests, You can refer to the previous phases of this exercise at:
https://dodgeforum.com/m_230964/mpag.../tm.htm#230964
https://dodgeforum.com/m_256104/mpag.../tm.htm#256104
Notes: Inbound highway for Phases 3-4 there were moderate head/cross winds.
Also, Phases Three and Four the ambient temperatures had risen sometimes to as high as 105 degrees, with very low (15-25%) humidity. The highway tests for Phase Four were in altitudes from 290-7000 ft. elevation.
Phase One-Stock everything
In Town, 15.3 and 16.1 for an average of 15.7 mpg
Highway, outbound, 26.7, inbound 28.5 for an average of 27.6 mpg
Phase Two-K and N drop in filter
In Town,17.1 and 16.8 for average of 16.95 mpg.
Highway, outbound 27.1, inbound 25.7 for an average of 25.7 mpg
Phase Three-K and N drop in filter and additional duct from grill to airbox.
In Town, 17.7 and 18.1 for an average of 17.9 mpg
Highway, outbound 29.1, inbound, 25.4 for an average of 27.25
Phase Four-K and N, additional duct, and double wall, triple insulated intake.
In Town, 15.9 and 16.4 for an average of 16.15 mpg.
Highway, first trip 1521 miles, 25.22 mpg overall. Best tank was 446 miles on 16 gallons, for average of 27.87 mpg. Best leg was 178 miles, 30.3 mpg.
Highway, second trip 1446 miles, 24.55 mpg overall. Best tank was 438 miles on 16.1 gallons for and average of 27.08 mpg. Best leg was 132 miles, 27.5 mpg.
Comments/Observations: Installing the K and N and the additional 3 inch duct seems to be the best and easiest mods. to do. The insulated duct in Phase 4 only cools the intake air slightly more than the stock system on the highway. In town the insulated duct runs cooler inlet air and recovers quicker, but as you can see did not render the best mileage. Ambient temperatures 95-100, with 15-25% humidity may have been a factor. I will also say that on the best tank (446 miles/16.0 gallons) and best leg of the first trip (30.3 mpg) were obtained using regular (87) fuel with 7 oz. of acetone added to the fuel. Best mileage was obtained at about 4500 ft. elevation.
--If I were doing this over, and drove mostly on the highway, I'd do the first two mods. only. (K and N and additional inlet to airbox)
--If most of my driving was in town, I'd do them all again.
--Weather conditions and speeds driven have more to do with gas mileage than any of these mods.
--Acetone does do some good on the highway with my vehicle. City???
--Bottom line, as proven before....the stock system isn't too bad at all, but with the high prices of fuel these days, every little bit helps, IMO.
