Help with Odometer on 2006 Magnum RT
Old Nov 24, 2012 | 11:48 PM
RoadKiller's Avatar
RoadKiller
Default Help with Odometer on 2006 Magnum RT
I need help diagnosing the odometer on my 2006 Magnum RT. It is showing a display of negative symbol, space, number 4, negative symbol, zero, number six (- 4-06). I've tried turning my ignition from ON to ACC to ON to ACC and back to ON, but nothing changes. I've pulled the #11 fuse, but no change and pressing the button that normally would scroll between the odometer, trip OD and temperature also does nothing. Anyone else have this problem? Any solutions?
Old Nov 26, 2012 | 01:34 PM
DodgeCares's Avatar
DodgeCares
Road,
I found one case with your symptoms. The recommended fix was a re-set by the dealer or disconnecting the battery for a few minutes to re-set.
Old Dec 7, 2012 | 07:27 AM
RoadKiller's Avatar
RoadKiller
Thanks for the info. I tried removing the fuse, but I will try the battery disconnect. As long as there is hope and I don't have to replace the cluster.
