Lil help....
Old Sep 16, 2005 | 07:04 PM
VooDooHemi's Avatar
VooDooHemi
Default Lil help....
Doing my first oil change on my '05 Magnum R/T. But it seems like I don't have the right size socket....and I can't believe there is a socket size that I don't own. Is there a special socket for the oil plug? Has anybody tried installing a quick drip oil plug yet? I tired to loosen with an adjustable wrench and with the slightest pressure, the bolt stripped a little bit so I'm planning on replacing it. Anybody have problems with this at all?
Old Sep 18, 2005 | 12:42 PM
MagnumRT's Avatar
MagnumRT
Default RE: Lil help....
The drain plug is metric, as in 13MM.
It is a good idea to replace the drain plug after a few oil changes, as the rubber gasket seal is part of the drain plug.
DO NOT OVER TIGHTEN!!!!!!!!!!!!!!!!!!!
New drain plug from the dealer runs about $6.
Bob
