DTC codes 0520, 0524, and 1521 wtf!
Old Oct 23, 2013 | 11:36 PM
9SEC6SPD's Avatar
9SEC6SPD
Default DTC codes 0520, 0524, and 1521 wtf!
well, the RT wagon dashboard is ringing and chiming
first 2 codes were oil pressure sensor malfunction, and secondly low oil pressure. i believe they are related (ha ha)
the third one is puzzling 1521 ? any tips on what could be causing this to trip?
tia!
Old Oct 23, 2013 | 11:48 PM
9SEC6SPD's Avatar
9SEC6SPD
actron says 1521 is wrong engine oil, lol! that is not what came up.i lost the paper with the descriptions, the first two were easy to remember, guess i need to go and recheck and write it down again.
Old Oct 24, 2013 | 12:20 AM
draftingmonkey's Avatar
draftingmonkey
It is possible that a bad oil pressure sensor that is throwing codes indicating a bad sensor and low oil pressure are causing the PCM to think it is incorrect oil. Here is an excerpt from the manual that may help:
NOTE: If set along with P1521, repair any engine oil pressure or temperature DTCs first before continuing.
The following conditions must be checked.
² OEM recommended oil viscosity is being used.
² Customer is following the oil change schedule.
² Check the engine oil for contamination. (i.e., fuel and/or engine coolant)
² Internal engine condition that may effect oil pressure.
Were any of the above condition found?
Yes >> Repair as necessary.
I'm betting on a bad sensor.
Old Oct 24, 2013 | 11:59 AM
9SEC6SPD's Avatar
9SEC6SPD
Is it true that the hemi has 2 oil pressure sensors? Just what I have heard.
Thanks again for your help!!!!
Old Oct 24, 2013 | 12:58 PM
draftingmonkey
Only 1 that I know about.
