need tires
Old Oct 10, 2005 | 08:41 AM
joemagnum's Avatar
joemagnum
Default need tires
I am looking for new tires for the Magnum RT rear wheel drive. I need all season tires. What are the fattest size I can run on stock rims? What is the "hot" tire in our size for all season use?
There does not seem to be too many choices!
Old Oct 10, 2005 | 03:56 PM
LtlDad's Avatar
LtlDad
Default RE: need tires
Do some checking, although I believe the largest size is 265/45, although some have put larger on the rear.
I thought for snow, a 'thinner' tire was better?
Old Oct 10, 2005 | 08:33 PM
joeb1's Avatar
joeb1
This is side by side with stock 225 60's and 245 55's from
http://www.1010tires.com/TireSizeCa...p?action=submit
Check the different sizes on the site. Don't go too overboard on size.
Stock Tire - 225/60R18
Tire 1 - 245/55R18
Section Width: 8.85 in 225 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: Unrecognized tire size.
Rim Width Range: 7 - 8.5 in
Overall Diameter: 28.62 in 726.94 mm
Overall Diameter: 28.61 in 726.69 mm
Sidewall Height: 5.31 in 134.87 mm
Sidewall Height: 5.30 in 134.62 mm
Radius: 14.31 in 363.47 mm
Radius: 14.30 in 363.22 mm
Circumference: 89.91 in 2283.7 mm
Circumference: 89.88 in 2282.9 mm
Revs per Mile: 726.7
Revs per Mile: 727.0
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.0 mph 100. km/h
Speedometer Difference: -
Speedometer Difference: 0.041% too fast
Diameter Difference: -
Diameter Difference: 0.04%
Joe B
Glendale, AZ
Magnum Owners Club
Southwest Chapter
Member # 1015
2005 Magnum RT
Inferno Red Tinted Pearl Coat
