Instrument panel bazel removel
Old Nov 10, 2005 | 06:04 PM
Magnum 2005's Avatar
Magnum 2005
Default Instrument panel bazel removel
How does the bazel around the instruments come off ??? does it pull off like I think it does
Old Nov 10, 2005 | 08:23 PM
chrisuscga01's Avatar
chrisuscga01
Default RE: Instrument panel bazel removel
yes it does. you will be good to start by the ash tray at the bottom where your car outlet is. open that up and you will be able to get your fingers in there to pull the bottom away. there is like three clips on each side. not too hard. just have to line up the vents when you put it back on. remember to unplug everything as you pull the bezel off. the cords don't allow for too much pull room.
Old Nov 12, 2005 | 08:30 PM
Magnum 2005
Thanks, used an old silver butter knife bent on the end to loosen it so I could get my fingers on it,,,,,,hate the white glare from the dash lights,,,,yes I know that I can dim them but when there dim its hard to see the other controls radio/ac/etc. will find a way to put some kind of film over the gauges to cut some of the glare....
Old Nov 16, 2005 | 02:19 AM
356MAGNUM's Avatar
356MAGNUM
ORIGINAL: Magnum 2005
Look at the local car parts place for some window tint. It should come in a couple of darkness tints. If not go to a place that tints windows. Heck you can even get different colors. Hey Grinner, if you read this , how about some purple tint for your gauges hahaha
