Interior lighting
Old Nov 7, 2017 | 01:02 AM
diamon708's Avatar
diamon708
Default Interior lighting
Hello everyone need some held with my 2005 dodge magnum hemi. I recently purchased some led interior bulbs to replace my old one. I put in the bulbs and everything was working fine for about a week. One day all the light went out map,trunk,and the two reading light for the passengers at all the same time. I put back in my original light now I have no power at all. On top of that I have had to get a jump two nights in a room after my car sat at work for 9hrs. I have checked every fuse in the car none blown, I have removed all the housing to the light to see in I get voltage to the plug when the door are open that fine. I have no more idea to try last option is the dealer smh. Any help would be great open to anything at this point.
Old Nov 7, 2017 | 07:15 AM
Moved to the correct section.
Old Nov 10, 2017 | 11:27 PM
draftingmonkey's Avatar
draftingmonkey
I replaced all the interior lights in my '05 Magnum with LED's with no issues. My guess is that the bulb replacement and your electrical issues are not related. I would chase the issue as if it is not bulb related and with the power drain causing you to have to get the vehicle jump started you may be looking at a short somewhere in the circuit that serves your interior lights. Just my thoughts.
Old Nov 11, 2017 | 01:06 AM
diamon708's Avatar
diamon708
Thanks that where I going to try these weekend hope to find the issue
