Car pulls to the left
Old Jan 22, 2018 | 09:26 PM
JohnnyG123's Avatar
JohnnyG123
Default Car pulls to the left
Hey out there! First time in, hope you can help me with my dilemma. I have a 2005 Dodge Magnum 5.7 Rt, AWD. I replaced rotors and front brakes last year with a competition set and everything was fine. This year I replaced the rear rotors and pads with Raybestos rotors and pads (the good ones). Shortly after replacement, my car starts to pull to the left. I pulled all the wheels and re-greased the slides on the brakes, I worked the pistons in and out front and rear 10-12 times each to make sure they weren`t sticking...... that didn`t help. Went back in and changed the pads from side to side on the front.......that didn`t help. Replaced all the brake fluid and bled starting from back to front...that didn`t help. Statistically, pulling to the left indicates a bad caliper so I went directly to Dodge and ordered a brand new one for the front left side.....didn`t change a thing. Any ideas out there?
Old Jan 22, 2018 | 09:29 PM
Rotate your tires. (provided the tires/wheels are the same size/backspacing/etc.) See if the pull moves, or changes at all.
Welcome to DF! You want to be in the Magnum section.
