2005 Dodge Magnum Transmission Problems
Old Jul 15, 2018 | 11:17 PM
05DodgeMagnum's Avatar
05DodgeMagnum
Default 2005 Dodge Magnum Transmission Problems
What's up guys I have a 2005 dodge magnum with a 2.7 l motor. I recently had a shop redo the rear main seal which I regret they did something g to the transmission. Its stuck in 2nd gear in limp mode. I dropped the pan and the fluid looked like water so I replaced the filter and put brand new fluid in but still didn't do the trick. Is there anything else I can check before dropping the valve body? I got p0750 on my scanner. The transmission was working fine before they did this. Any help would be awesome I love my magnum thanks.
Old Jul 16, 2018 | 07:49 AM
The obvious response is take it up with the shop that messed it up.....why would you not do that?
Old Jul 16, 2018 | 08:18 AM
05DodgeMagnum
Because it sat there for 6 months and they could not figure it out so I recently towed it home so I could try to find the problem.
Old Jul 16, 2018 | 10:09 AM
Aw man.... that sucks. The fluid looked like water, meaning it was clear?
Old Jul 16, 2018 | 10:45 AM
05DodgeMagnum
it looked like water it was red but real thin. I dont know how to resize
Old Jul 17, 2018 | 10:02 AM
05DodgeMagnum
Is there any way to check the ohms on the speed sensors? Or what can I check before replaci.g the solenoid pack?
Old Jul 17, 2018 | 12:54 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Take another picture please.
Old Jul 17, 2018 | 02:11 PM
05DodgeMagnum
Old Jul 17, 2018 | 02:12 PM
05DodgeMagnum
That was when I first dropped the pan. I've replaced the filter and fluid.
Old Jul 17, 2018 | 06:56 PM
05DodgeMagnum
Anybody know the connector name this was located on top of the transmission the top right one was tore they tried to sauder it but it came off. I'm hoping this is causing the problem. They tore 1 wire but had enough to fix it.
