2007 Magnum shifter and gauge
Old Aug 14, 2020 | 05:15 PM
deermit's Avatar
deermit
Default 2007 Magnum shifter and gauge
Hello All, I have a 2007 Magnum that is driving me crazy!
It will run perfect for several days and then the engine will shut off without warning, the gear shifter will stick in park (it has the new interlocks and they are intact) the brake lights work fine when the shifter acts up, the gas gauge will fluctuate from full to empty in a few seconds and the transmission will have an occasional hard shift. If I restart the engine sometimes everything works correctly but most of the time it won't. The only code it throws is for the gas sending unit which appears to be working fine.
I have replaced the battery, checked and cleaned the ground wires, ran a new ground wire from the ECM to ground, I've tried to make sure the EMC pins were straight and corrosion free.
Can anybody think of what I might be missing? Thanks
