Speedometer cluster
Old Jan 16, 2021 | 03:57 PM
Chief116's Avatar
Chief116
Default Speedometer cluster
2006 AWD RT. The tach gauge digital display for the gear selection/throttle body lighting bolt display keeps going out. It comes and goes with no set pattern I can determine. What connection supplies this? I have cleaned all the grounds, pulled the speedo and checked all pins, no corrosion or bent pins.
has anyone else seen this? I have been searching with no luck.
Old Jan 21, 2021 | 09:35 PM
Chief116's Avatar
Chief116
Anyone? come on guys help me out if you have any ideas.
Old Jan 17, 2022 | 12:19 AM
RoadBoss2's Avatar
RoadBoss2
Have you try a scan too first and see if any communication codes comes up ?
Not sure if solved , but I try to install a different radio in my 2005 , switching stock radio to a Mygig ,
And one defect radio I bought for cheap was causing things to blink.
Your best bet would be to try disconnecting accessories on the CAN bus B one at a time .
If all comes back good , the one you removed might be the offending components.
Cycle the key between every change so all reboot.
Old Jan 17, 2022 | 02:42 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
You kinda picked the wrong forum to ask questions like that. There is an LX forum (hint) that probably has what you need.
