Auto-up window not working
Old Feb 13, 2006 | 02:26 PM
kowalcs's Avatar
kowalcs
Default Auto-up window not working
Well, after my last dealership debacle (see "ITIOTS AT DEALER DAMAGED MY ROOF THREAD"), I am really hesitant to take my car back to the dealer, but I might have to. My automatic power window on the driver's door stopped working. It works when going down, but the auto-up on the driver's door only, has stopped working. I have to hold the switch to get the window to go all the way up. Anyone have any experience with these? It is possibly just a dirty switch? Can I fix this myself without the dealer touching it? How hard is it to get to the switch? Any help would be appreciated. Thanks.
Old Feb 13, 2006 | 03:09 PM
snide's Avatar
snide
Default RE: Auto-up window not working
I've never seen an auto up feature on the windows. Not from the factory, anyway...
Old Feb 13, 2006 | 03:18 PM
MagnumRT's Avatar
MagnumRT
No such feature on my 2005 Dodge Magnum........................
Bob
Old Feb 13, 2006 | 05:10 PM
kowalcs's Avatar
kowalcs
You guys sure? It works on the passenger door for sure. I could have sworn it worked on the driver's door too at one time. Mine's a 2006 model. I know it worked before. Like I said, the front passenger door has auto-up.
Old Feb 13, 2006 | 06:18 PM
shiltz's Avatar
shiltz
You can get one touch up on both front windows on an 06 magnum, it's in one of the convience group packages. I don't have that on mine though so can't help really there.
Old Feb 13, 2006 | 10:54 PM
65standard's Avatar
65standard
only on the '06 magnums. i have this feature. if you disconnected the battery, you will need to reset this feature.
push and hold the button down until the window is all the way down, continue to hold the button for another second or two until you hear the click sound. repeat this process to reset the up feature. hold the button up until you hear the click.
the next time you use this auto up auto down feature, it will work as before. do the same for the other window too.
Old Feb 14, 2006 | 12:17 AM
kowalcs's Avatar
kowalcs
ORIGINAL: 65standard
Well, this evening when I pulled up to the mailbox, I used the auto down and then hit the switch to go up and it worked this time. Strange. I wonder why it wasn't working for the last few days. I never disconnected the battery. Hopefully it's just a fluke. Thanks for the info, guys!
Old Feb 14, 2006 | 08:38 PM
strippedhemi's Avatar
strippedhemi
Interesting, I never heard of a car having power up. Its a safety thing so someone dont roll it up on their finger or neck . The only time I seen it was on 58-60 Lincoln convertibles where it put up the top and all of the windows if a sensor got hit with water. I def wouldnt want it to go up on auto on mine.
Old Feb 14, 2006 | 11:12 PM
via500's Avatar
via500
ORIGINAL: strippedhemi
Our 1998 Mercedes C280 Sport has auto up/down and by then it was across the Mercedes line. It uses pressure sensors to detect anything in the way.
Old Feb 15, 2006 | 10:35 AM
kowalcs's Avatar
kowalcs
Our 2005 Volvo XC90 has auto-up too. Yeah, it's got pinch sensors so the window doesn't take your finger off.
