Do RT's have a 4,000 rpm limit?
4,000 rpm limiter
[QUOTE=2005 Magnum R/T Hemi;425379]40 in 1st Gear
70 in 2nd Gear
113 in 3rd Gear
My '05 RT has done this since Mile 6... (on the way home from the dealer)
DC couldn't find tires to allow me to see what 4th Gear does...
Nice smooth computer controlled Auto Shut down at 127 MPH...
However, I have heard that the SRT-8 Models have the speed limiter removed, but the engine rev limiter stops it 172 MPH. 172 MPH!!!
[img]local://upfiles/10346/CE49994425D644A99B64833AECDB844E.jpg[/img][/QUOTE
I have a 2006 Charger SRT8 and my RPMs won't go higher than 4,000 in park. Is that normal? I remember my 06 Chrysler 300c srt8 did but it may have been shut off by a previous owner that added some upgrades.
70 in 2nd Gear
113 in 3rd Gear
First, I can't believe you necromanced a 14yr old corpse thread.
Secondly, yes that is normal. Not supposed to rev an engine that high or higher not under a load; why would you want to to do that? You trying to blow it up? Your 300 was messed with to remove that limiter.
Probably because I'm trying to figure out why my car won't run right! I bought it in november of last year and haven't been able to do anything with it since I got it and the 3 different Dodge dealerships I've taken it to can't fix it! So excuse the **** outta me for running across the one post I found about it!
I am however insanely curious as to what line of troubleshooting led you to needing to rev your engine past 4000rpm in neutral or park....especially you haven't listed AT ALL what an actual problem is. Having a factory rev limiter when the car isn't in gear is not a problem lol.
Triggered much lol
No STOCK American computer controlled vehicle (pretty much since the mid/late 90's) allows the engine to be revved past 4000 in neutral or park; that's no load free wheeling and you can f@ck it up royally doing that. It's not a defect, it's designed in; leave it alone. As for your stalling problem, are any codes present? Usually those symptoms are either fuel system problem like bad fuel; you said tank was changed, but did they bother to look at either fuel pump (accessible under the front seat)? Or could be an electrical problem like bad grounds, clapped out battery, weak alternator. LX's are extremely voltage sensitive. Did they bother to run a compression test?
