MPH
Old Apr 17, 2006 | 01:49 PM
CHARGER R/T's Avatar
CHARGER R/T
Default MPH
Whats the fastest you have taken your Magnum?
Old Apr 17, 2006 | 05:33 PM
Strykker's Avatar
Strykker
Default RE: MPH
I only drive the speed limit...officer friendly are you reading this, I did not race that car. That depends on your definition of RACING.
Old Apr 17, 2006 | 05:46 PM
06MNRT's Avatar
06MNRT
Default RE: MPH
145 with a lot left to go. I don't think I'll be taking it past 160 or so because I don;t believe the magnum's aerodynamics are really well suited for a higher speed.
When I had my R/T I maxed it out a number of times. (128 hits the limiter on the R/T).
Old Apr 17, 2006 | 08:02 PM
grinner's Avatar
grinner
Default RE: MPH
127
a flashpaq will fix that...
Old Apr 18, 2006 | 01:56 PM
hipsterj's Avatar
hipsterj
Default RE: MPH
Gawd I am slow!
105 when new last fall, wife won't let me drive on the great open road any more!
MNRT ---- 145?
SRT8 has no limiter? WOW
Want to try it at the max, but I need to sneak away with it.
Old Apr 18, 2006 | 02:30 PM
mangum's Avatar
mangum
Default RE: MPH
ORIGINAL: 06MNRT
As stated above, you can set the speed limiter to 200 MPH with Flashpaq if you want. I've read of a 300C with Hemi doing 170 MPH + and basically the same engine. Magnum is a couple hundered pounds heavier.
Old Apr 22, 2006 | 02:38 AM
Marmaduke's Avatar
Marmaduke
Default RE: MPH
140 MPH on the highway...
272 Kph - approx 170 Mph in forth gear on the dyno today.
Old May 5, 2006 | 02:47 AM
MaDd0g's Avatar
MaDd0g
Default RE: MPH
120 for me and the speed limiter set in...argh...just programmed it with my flashpaq to allow up to 255. doubt i will see that anytime soon.
Old May 5, 2006 | 03:55 AM
Jaime340's Avatar
Jaime340
Default RE: MPH
125 for me, but whats a flashpaq is it easy to instal? whats the price for one? it be sweet to go 160, well at least more than 125 and capable if i wanted to do 160
Old May 5, 2006 | 10:49 AM
MagnumRT's Avatar
MagnumRT
Default RE: MPH
For now it is 128 MPH, as soon as I get better tires, I will raise the speed limiter up with my Flashpaq.
Car should do at least 150 MPH.
Bob
