Can a factury installed Sirius unit be converted to XM
Old May 8, 2006 | 06:29 PM
bossman284's Avatar
bossman284
Default Can a factury installed Sirius unit be converted to XM
I have a Magnum with a factory installed sirius radio/navigation system. I'm a XM subscriber and would rather have my indash unit recieve XM as opposed to having to velcro my protable unit to the dash. Is it possible to have something changed/replaced in my unit to make it recieve XM instead?
Thanks for the help!
Old May 8, 2006 | 08:33 PM
joeb1's Avatar
joeb1
Default RE: Can a factury installed Sirius unit be converted to XM
You will need to change the WHOLE radio. The innerds are serius.
Joe B
Glendale, AZ
Magnum Owners Club
Southwest Chapter
Member # 1015
2005 Magnum RT
Inferno Red Tinted Pearl Coat
Old May 9, 2006 | 02:24 AM
CHARGER R/T's Avatar
CHARGER R/T
Hey man, I work at Circuit City Roadshop, and I have had people ask me that question all the time, and as of right now, the answer is no. You would need a radio that is XM ready or Satelite Radio ready.
Im working on a solution of getteing an FM modulator for stock radios and a XM reciver(Brain). I'll update.
Old May 9, 2006 | 02:28 AM
RTPablo's Avatar
RTPablo
Can you hook up an XM receiver through an aux input? Pereipheral is supposed to release and aux in in a day or so.
Old May 9, 2006 | 03:10 AM
bossman284's Avatar
bossman284
Ok. So I can't change the service on that radio...next question.
Is there anyway of adding a 1/8" mini aux/jack to my existing system so I can line in my current xm portable, as opposed to using the fm transmitter which seems to not work too well in my area.
Old May 9, 2006 | 02:04 PM
RTPablo's Avatar
RTPablo
Bossman,
Check this out. It may work for you.
http://peripheralelectronics.com/web...n.asp#CHRYSLER
It is supposed to be available now. They responded to my email questions about ipod interface quickly. Might be worth the email.
It will give you 2 RCA inputs, which you could then use an adapter to get 1/8" unless you can use the rca inputs.
Pablo
Old May 9, 2006 | 05:14 PM
bossman284's Avatar
bossman284
Ok. Thanks for the tip. After talking with peripheral it looks like this unit is going to work just fine. All I need to do is remove the siruis tunner and plug this unit instead
Final question. Can someone point me in the right direction for instructions on how to take a mangnum's dashboard apart. I've worked on radios in the past but I don't want to screw this one up!
Thanks for all your help.
Bill
