window problems
Old 07-12-2006 | 01:54 AM
Tedman5's Avatar
Tedman5
Default RE: window problems
left rear too....intermittent
Old 07-12-2006 | 11:15 AM
Silver bullit's Avatar
Silver bullit
I have not ever used my left rear and reading all of this i dont know if i ever will. Its going to the dealer today to replace the rear hatch glass and i am going to move the window up and down on the left side to see if any thing happens .I will be at the dealer already so they will see if any thing happens.
Old 07-12-2006 | 02:41 PM
CarFinish's Avatar
CarFinish
ok it's working again...and I forgot to stop by dealer when t wasn't...I know you don't want to know everytime, but it's a little comical at this point; ok maybe not
Old 07-12-2006 | 03:44 PM
Magmania's Avatar
Magmania
ORIGINAL: 65standard
i had the same problem with the left rear window not working. i told the dealer about it, they ordered a new regulator for me, but on my way to the dealer to get it installed, the window started working again after i slammed the door closed. they replaced the regulator anyways and have never had a problem since.
tell them it is an intermitted problem and to replace the damn regulator. believe me, dodge knows about this problem.
65standard is right. Dodge knows about this problem so they should just go ahead and replace the part (whether or not if it's working).
Old 07-13-2006 | 10:00 AM
kowalcs's Avatar
kowalcs
ORIGINAL: jokerdog
Not sure if this is what you mean but for damn near a week straight I thought I was tripping about the auto up and down feature on the driver and passenger window. They would both auto down but then for some odd reason the passenger side stopped doing the auto up feature. My short term memory is a little strained due to my extracuricular smoking activity's so I thought I was mistaken and that the auto up feature was only on the drivers side.
Then sure enough, out of the blue, the passenger side auto up feature just started to work again one day. Now that I know its actually supposed to do that I would guess that the safety feature that is supposed to detect resistance to keep you from rolling the window up on your arm/head/pecker is likley adjustable. But it isn't broke any more so I'm good to go for the moment.
If it happens again I'm going straight to the dealer.
Hope this helps...
-Tory
San Jose
I've had the same issue with my auto-up on both front windows. There is a procedure in your owner's manual to get it working again. That worked for me. Not sure what has caused it to stop working though.
Quick Reply: window problems
