Hoods
At present the only thing available is the RK Viper Hood: RK Sport
There are some concepts that are suppose to be near production. Good Hood which Keystone carries is one manufacturer: Keystone Restyling
I have a custom RK Sport Viper Hood. I had them overlay it with Carbon Fiber then blocked and painted it leaving only the scoop clearcoated carbon fiber...
First phase is that I just painted the hood the Stock Inferno Red. LAter I two-toned it with my custom Inferno Black from the front fascia to the rear spoiler. The Inferno Black uses the same red flake metallic as the Inferno Red.
Then I iinstalled the SRT8 front end and repainted with the same theme.
Take a look...
Take a look...
goodhoodguy, I have been in touch through email with keystonerestyling.com, which I assume you are a part of, and I was wondering if there will be a groupbuy offered to us at dodgeforums. You can count me in if you do this. I am torn between the 2 hoods, and I will end up choosing the one I can get the best price shipped to canada!
there are two different shaker hoods for the magnum, well three actually.
1) CDC shaker hood where you cut your original aluminum hood and use a custom scoop something like the 1970 original
2) MoPower where you cut a hole in your original aluminum hood and use an original 1970 mopar shaker scoop
3) MoPower fiberglass hood and original mopar scoop
Trending Topics
here are some pictures of the MoPower hood. the divider of the scoop is thin.
these are actually original scoops. one uses the stock hood that is cut open
and the other one uses a whole new fiberglass hood.
[IMG]local://upfiles/13006/4F96FEACD15A48D99A66B0F1491C3B0D.jpg[/IMG]
[IMG]local://upfiles/13006/4ED55B9E4FFA4D64A10B794E7C9049EA.jpg[/IMG]
