Power windows problem
Old Oct 24, 2006 | 01:55 AM
bburton166's Avatar
bburton166
Default Power windows problem
I have a 05 magnum and had the driver's side window start going up crooked (back end higher than the front). Today, the window tried to go up and then just dropped. I still have motor noise coming from inside door, and I can lift the window out with my finger tips, but then the window just drops back down into the door. Any thoughts?
Old Oct 24, 2006 | 02:08 AM
mommasride's Avatar
mommasride
Default RE: Power windows problem
Hey---I won't be alot of help, but I did have that happen several times on a maxima I used to have. Required replacing the motor each time, once hubby did himself. Just dont push the button to hear the motor noise or you will burn it up. Good luck.
Old Oct 24, 2006 | 03:30 AM
Magmania's Avatar
Magmania
It sounds like it is something that would be covered under the warranty ...hopefully.
I would just let my service department handle it.
Old Oct 24, 2006 | 04:11 PM
bossman284's Avatar
bossman284
I had the same thing on my 05 rear driver's side window. They need to replace a "window actuator". Of course it took 7 weeks to get the "back ordered" part...
Old Nov 3, 2006 | 07:11 PM
strippedhemi's Avatar
strippedhemi
definately a defective regulator / actuator. Usually the cheap motors crap out but it dont sound like this in your case. Not having been inside one of these doors myself yet, I dont know if they use gears and levers or a nylon strip to drive the windows. If there nylon, Ive seen them snap especially when its cold out and or window has frozen up with ice and you try to use it.
Old Nov 20, 2006 | 07:02 AM
MusicMan69's Avatar
MusicMan69
New Member
never had that happen but my rear window's work one day then the next one side won't work at all then it will work again a few days later and it switches sides!! Whats up with that???
p.s. just had to say it is so HOT when Strippedhemi talks car talk ;-)
