O-Rings on trans replace
Old Nov 7, 2006 | 11:25 PM
MAGNUM555's Avatar
MAGNUM555
Default O-Rings on trans replace
My Magnum just rolled over 7k miles. I noticed a small pool of fluid under the car. I just had the O-rings on my trans replaced. Anyone else have this problem? - Thanks
Old Nov 10, 2006 | 01:50 PM
hazz's Avatar
hazz
Default RE: O-Rings on trans replace
I had the same problem 2006 sxt at 4k.It took the dealer 45 min to fix it they also said there is a recall.
Old Nov 13, 2006 | 02:15 PM
Yates's Avatar
Yates
Same thing here purchased an 06 Magnum R/T brand new from dealer. Had about 10,000 miles on it before it started to leak tranny fluid. Took it to the dealer 3 times before they realized it was the O-Rings that were leaking. Changed em and haven't had a problem ever since.
Old Nov 14, 2006 | 12:00 AM
65standard's Avatar
65standard
i think almost every car has at least small seepage. i need to get mine fixed too.
Old Nov 17, 2006 | 09:44 PM
MattRobertson's Avatar
MattRobertson
Its tranny fluid, right? Oily and dark red (use a white paper towel to sop some up). My RT's air conditioner drips water after a stop in almost the same spot.
Old Jan 15, 2007 | 01:29 PM
magnum_ocd's Avatar
magnum_ocd
have 27k on mine and just had to have the same thing done. having numerous warranty issues with this car. wouldn't give it up for anything though.
Old Jan 18, 2007 | 12:17 AM
kowalcs's Avatar
kowalcs
Had mine replaced at around 15,000 miles. Very common issue.
Old Jan 18, 2007 | 12:42 AM
03neonRT's Avatar
03neonRT
Had them replaced on our '06 R/T at 13k as well...
