Header install question
Old Feb 9, 2007 | 05:32 PM
Yates's Avatar
Yates
Default Header install question
I am currently in the market for some aftermarket headers for my 06 R/T. I think I am going to go with the JBA stainless steel shorty headers for 400.00. Can anyone tell me how hard is the install or is it as easy as they claim. Will I be able to just take off the exhaust manifolds from underneath and replace with the JBA headers? Or does anything have to be customized to get them to fit?
Old Feb 9, 2007 | 11:12 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Header install question
I helped a friend from Houston put JBAs on his Magie, it's just like any other 5.7 LX. There are a couple bolts that make it a pain the butt.
Yes exhaust manifolds will come out from underneath and the JBAs will slide right in their place with no issues hooking up to the CAT/Midpipes.
Check out this PDF I put together on the install. (couldn't get the embedded link to work so here’s the url)
http://home.comcast.net/~rgdixon/Cha...derInstall.pdf
<edit> I need to revise the PDF, Breslin header bolts are no longer available. You can try Stage 8 BoltsPart # 8916(17) 8mm-1.25x25mm 6pt DHH www.stage8.com
Old Feb 10, 2007 | 01:51 PM
Yates's Avatar
Yates
Hey thanks for the info and site I greatly appreciate your input
