esp base light
Old Feb 10, 2007 | 06:25 AM
dodgestealth's Avatar
dodgestealth
Default esp base light
hello
i have the esp base light
what is the problem?
the switch esp is ok!!!
Old Feb 10, 2007 | 01:25 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: esp base light
Check fuses (black diodes) 31 & 32 in truck fuse box, pull and re-seat them. They may have come loose: 31 - TCM connection 32 - Accelerometer connection.[/align][/align]
If that doesn't work:[/align]Pull/re-seat fuse 11 in the engine compartment fuse box.
[/align]If that doesn't work:[/align]Pull the negative battery cable and re-connect it.[/align][/align]If the light doesn't go away after all that then theres a deeper rooted problem, take it to a dealer. It could be a bad sensor somewhere.[/align][/align]Good luck![/align][/align][/align]
Old Feb 10, 2007 | 05:02 PM
dodgestealth
yes ok i will see
