Any vibration problems?
Old Jul 6, 2008 | 02:39 PM
Black RT's Avatar
Black RT
Default RE: Any vibration problems?
No deformities in my tire sidewalls>>>My vibration was worse from 45-60 miles MPH>>>but could feel it and any speed>>>Did your tire dealer tell you how each tire forced balance out>>>If they are just a little out the Magnum will let you know>>>If you have a friend with the AWD set up and he will let you switch tires and wheel for a test drive and then you will know for sure it it is tires>>>Hope you find problem.
Old Jul 6, 2008 | 10:23 PM
deezozdodge's Avatar
deezozdodge
no deformities in tires. the problem occured when i hit the island curb while making a left turn. i think it is driveshaft or ball joint. i only feel vibration over 65 mph while negotiating right freeway curves.
Old Jul 12, 2008 | 09:53 PM
deezozdodge
Update on vibrations: changed inner tie rod bushings. The old ones was all chewed up, causing the shimmy in the wheel. (A simple fix for only $15.00 and an hour and a half)
