Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
Solid State Voltage Limiter
Old Feb 6, 2005 | 05:10 PM
fc7gtx's Avatar
fc7gtx
Default Solid State Voltage Limiter
I've been wanting to switch out my current voltage limiter on the back of my gauges for a solid state limiter. They say they are more stable and feed a constant 5 volts to the gauges without that annoying spike you might see from time to time. Well this company sells them for around $40.00:gcatrim Then I saw a post about building one yourself. I had seen the tech aryticle before but decided to try it mysself. It looks simple. Here's the link to the article:Voltage Limiter Well I went out and bought the items that I need for the mod. I managed to buy all the parts from Radio Shack for $4.27. Hope this helps anybody that might want to upgrade their voltage limiter or if your not into making one then buy one from gcartrim.
Old Feb 6, 2005 | 11:05 PM
moparturd's Avatar
moparturd
Default RE: Solid State Voltage Limiter
Looks like a good article. I'll have to read it and get back to this thread.
Old Feb 8, 2005 | 04:36 AM
71RoadRunner's Avatar
71RoadRunner
That's a great article, thanks for the link. My gas gauge has only worked twice since I've had my Roadrunner and that's been over 11 years.[:@]
Old Feb 10, 2005 | 10:06 PM
fc7gtx's Avatar
fc7gtx
Well I started the soldering of the Solid State VL. After going through the steps of the article I found out that I was able to vary the procedure a bit but it would still work if you followed it. I still have to solder the original top board terminals but that's about it. I tested it and with 12VDC input it puts out 4.93VDC constant. I imagine that if you would buy ten Voltage Regulators they would all have a slightly different output but 4.93VDC is very close. I should have it ready to install tomorrow. Now for the hard part, getting under the dash.... Not bad for less then $5.00
Chris
[IMG]local://upfiles/11901/AEDB0048C2954A5799E0A48C1B472029.jpg[/IMG]
[IMG]local://upfiles/11901/7B81EA44335B4F38A77A7D2740722C73.jpg[/IMG]
Old Feb 11, 2005 | 11:05 AM
71RoadRunner
Very nice, I can't wait to here how well it does.
Old Feb 13, 2005 | 12:20 AM
fc7gtx's Avatar
fc7gtx
ORIGINAL: 71RoadRunner
Well I managed to pull the front seat and crawl under the dash and plugged in my new and improved Voltage Limiter. Works like a champ.
[sm=smiley20.gif]
Chris
Old Feb 13, 2005 | 06:32 AM
71RoadRunner
Great, glad to hear it! Now I just need to figure out which cluster type I have and they maybe do the same to mine.
