Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
440 6bbl Operating temperature
Old Jul 2, 2004 | 11:20 AM
dderal's Avatar
dderal
Default 440 6bbl Operating temperature
I am wondering what temperature I should be runnng at. My 440 6pk, bored over .030 is said to be at 525hp. I had an undersized radiator that had me running at about 210 in non stressful situations and well over 220 in slow traffic. Yesterday I installed a new aluminum radiator with built in tranny cooler, I removed the thermostat, ran water only (with an additive for better cooling), and installed a finned aluminum oil filter cover. Now I run at about 170 in non stressful situations and about 190 in non moving traffic. What is the ideal temperature for my engine?
Old Jul 2, 2004 | 03:36 PM
moparturd's Avatar
moparturd
Default RE: 440 6bbl Operating temperature
Your in it. Sounds like there is enough heat, but not to much.
Old Jul 3, 2004 | 03:08 PM
71RoadRunner's Avatar
71RoadRunner
Yeah, your right where you want to be alright. My dad's Charger runs way hot and it already has a huge Be Cool aluminum radiator as well as a Mopar Performance aluminum water pump housing and an aluminum water pump. I think he needs to get an electric fan too.
Old Jul 3, 2004 | 04:49 PM
Deleted User's Avatar
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Jul 5, 2004 | 02:55 PM
d0z3r's Avatar
d0z3r
wow...the timing on me finding this forum is great!!!! a good bud of mine just took delivery of a 73 challenger with a 440 six pack. couple days ago while doin the local 4th of july parade, it overheated. which has led to a minor debate over the coolant to water mixture/ratio he should have..... especially down here in orlando during the summer. the builder thinks 50-50. a good friend who has a 57 chevy lives by 75% water-25% coolant.
any more experienced suggestions, especially with the southeastern temps?? different mixture, for different seasons???
thanks
d[8D]z3r
Old Jul 6, 2004 | 05:00 AM
71RoadRunner
Pure water will have the best transfer of heat out of the engine for better cooling. But the antifreeze lessens the corrosion and raises the boiling point of the water. For the summer time I would go with a higer water content and a lower antifreeze content, but don't forget to change it come winter time even though it is in Florida. Also try a product called Water Wetter, it will also help to transfer the heat out of the engine and lower the operating temp.
Old Jul 9, 2004 | 04:18 PM
d0z3r's Avatar
d0z3r
hey, thanks a mil, man!!!
we're gonna flush it out this weekend, and go w/a more water heavy mix......gonna check out that water wetter stuff too...thanks for your reply...
mucho appreciated!!!
d[8D]z3r
Old Jul 10, 2004 | 08:03 AM
71RoadRunner
Not a problem. Good luck with the cool down.[sm=smiley20.gif]
