Dodge Muscle Cars When it was all about noise and big (and bigger) engines, Dodge and Plymouth ruled the roads. Discuss the Muscle cars that once were within.
Cam walk in 440???
Old Aug 12, 2004 | 01:21 PM
hosse's Avatar
hosse
Default Cam walk in 440???
Wondering how to combat cam walk in a early 70's 440?
Old Aug 13, 2004 | 06:03 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Cam walk in 440???
Cam walk is more known to happen in the 383, but no matter there is a cure. You need a cam button. It is a spring loaded button that keeps the cam from walking out. Here is a few direct links to this item:
http://www.jegs.com/cgi-bin/ncommerc...53&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...20&prmenbr=361
For this link, after you click on it and the page loads, to the left there is a list of parts and you need to click on "engine". After that on the right under Comp Cams click on "camshaft thrust button":http://www.yearone.com/serverfiles/f...ain2.asp?cat=1
Go luck with your Mopar.[sm=smiley20.gif][sm=smiley2.gif]
