IS IT POSSIBLE ??? VALVE QUESTION
Old Sep 6, 2004 | 01:34 AM
tyson724's Avatar
tyson724
Default IS IT POSSIBLE ??? VALVE QUESTION
IS IT POSSIBLE THAT AN INTAKE AND EXHAUST VALVE CAN BE PUT IN WRONG ? FOR EXAMPLE: EXHAUST VALVE INSTALLED ON INTAKE SIDE ?
WOULD THIS CAUSE A BAD TAPPING NOISE FROM THE CYLINDER HEAD?
[IMG]local://upfiles/4785/6D459BD6BA2C4ABDA637BC9738CC7610.jpg[/IMG]
Old Sep 6, 2004 | 01:55 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: IS IT POSSIBLE ??? VALVE QUESTION
Didn't you just ask this question in your other thread?
No, it is not possible. They can only go in one way. I'd say it's either a lifter or your rockers. And just because it's running good now doe not mean they are good. I'd seriously pull it apart and take a look. Because in the long run you are doing more good than harm.
Old Sep 6, 2004 | 08:58 PM
Altima_wb's Avatar
Altima_wb
1. No its not possible if it is thats not your probablem. 2. reading posts that are typed in full CAPS is annoying as hell.
Old Sep 6, 2004 | 09:00 PM
Cr@zy Squ33
That's three times he's been told no.
Old Sep 7, 2004 | 12:56 PM
Altima_wb's Avatar
Altima_wb
ORIGINAL: Crazy Squee
And thats just about as annoying as reading caps
Old Sep 7, 2004 | 11:15 PM
Cr@zy Squ33
And having two threads asking the same question is also annoying.
Old Sep 8, 2004 | 12:08 AM
tyson724's Avatar
tyson724
Crazy Squee
was wrong !!!!! i pulled head and found 2 valves put in wrong !!!!!!
so Crazy Squee dont answer ??s with wrong answers !!!!!!!!!!!!!!!!!!!!!
Old Sep 8, 2004 | 12:28 PM
Altima_wb's Avatar
Altima_wb
He wasn't totally wrong its really shouldn't have happened any machine shop worth anything should have known better then that, so you should be finding a different shop to get work done at.
Old Sep 8, 2004 | 01:05 PM
Cr@zy Squ33
Valves can be put in wrong. In your other thread you had asked if the rockers could be installed wrong. I actually didn't read your entire post because I just saw IS IT POSSIBLE and then saw that it was you so I had thought you were asking the same exact question.
Old Sep 10, 2004 | 02:07 AM
casper's Avatar
casper
Where did the machine shop get their experience from a hooked on phonics book or a cracker jack box? No, No its gotta be a Honda dealership.
