Blowing Fuel Pump Fuse
Old Sep 10, 2004 | 02:48 AM
sakirider's Avatar
sakirider
Default Blowing Fuel Pump Fuse
I have a 97 SOHC Neon, and the fuel pump fuse keeps blowing. I was told it was probably the fuel pump, so I changed that, and the car ran fine for about 2 weeks. Now the fuel pump fuse just blew again. Anyone have a idea about what could be causing this or have a similar experience? Thanks
Old Sep 10, 2004 | 02:58 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: Blowing Fuel Pump Fuse
Sounds almost like a pinched wire somewhere int eh fuel pump circuit. I'd trace the wire and look for breaks or shorts in it.
I had an issue with mine blowing the fuel pump fuse a few days after I installed a kill-switch but somehow the wires came out from under the carpet and got pinched by the door.
Old Sep 10, 2004 | 03:05 AM
casper's Avatar
casper
There was another person on here that had the same problem, If I remember correctly it was a pinched wire. Search the forum for fuel pump you should pull it up.
Old Sep 10, 2004 | 11:43 PM
sakirider's Avatar
sakirider
Ok...checking out the wiring right now.....will post back if I find anything at all to report..thanks for the comments on what to look for.
Old Sep 11, 2004 | 12:47 AM
sakirider's Avatar
sakirider
Ok...the only thing I really found was two wires going to a fuel injector were exposed. It did not look like they were touching each other or grounding off anything, but I believe they could be arcing off each other possibly, so hopefully thats what it was. Thanks guys.
Old Sep 13, 2004 | 01:17 AM
casper's Avatar
casper
I am almost positive that they are on the same circut. It was stated in the other post, I will see if I can find it.
