The turbo itself? Yes. I've seen it a lot it's a small T3 generally a 16 or between a 14B and 14B depending on year. But as for the entire engine I've only seen it once.
doesnt a turbo take life away from an engine?? im just wondering b/c i dont know much about turbos.
I have and yes if a turbo setup is done incorrectly it can take life away form your engine. But if done correctly and you are not obsesed with pushing the limits of your engine then no your engine will run just as long as an na motor.
lol well that would mess an engine up...Hey anyone know where i can find directs on know exactly what to do from taking the turbo and manifold off the eclipse to putting it on the neon?obsesed with pushing the limits of your engine
I really don't suggest using the Elcipse Turbo. Really. You'll have to do a lot more internal engine work for it. It creates a lot of heat compared to a larger turbo.
