2.4L Engine rebuild question
Old May 14, 2007 | 01:59 PM
Dan877's Avatar
Dan877
Default 2.4L Engine rebuild question
I got a salvage Stratus and pulled the 2.4l engine to rebuild. My Haynes manual doesn't explain how to remove the "counterbalancer" mechanism on the bottom of the engine to allow access to the rod/main bolts. Does anyone know how it comes out? It's chain driven,is it timed? Does anyone know if Chilton has a manul that is more detailed about the 2.4L engine?
Thanks for any help
Dan
Old May 14, 2007 | 06:16 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: 2.4L Engine rebuild question
go to the stratus forum and ask them!
Old May 14, 2007 | 09:17 PM
Dan877's Avatar
Dan877
Actually, the engine is going into a Caravan, but its the same 2.4l engine as in the Neon (and a bunch of other Chrysler models). From reading posts it appears more Neon'er have rebuilt their 2.4l engine than in any other forum, so I thought this would be a good place to ask a general engine question.
Dan
Old May 15, 2007 | 11:53 AM
Dan877's Avatar
Dan877
I found the information I needed. Turned out it's in the Haynes manual after all, just not in the place I thought it would be. The engine rebuild chapter jumps back and forth between the 4 cyl. and 6 cyl. engines, kind of confusing at first.
Thanks
Old May 16, 2007 | 02:42 PM
das2123's Avatar
das2123
ORIGINAL: Dan877
The 2.4L engine did not come in any neon from the factory (excluding the 2.4 turbocharged engine on the SRT-4).
They share the same head, but different blocks.
