Panic Alarm
Old May 20, 2007 | 02:10 AM
gearue's Avatar
gearue
Default Panic Alarm
For no reason,panic alarm goes on.I turn it off andan hour or so later it goes on again.Where shouldI start.Keys are on dresser.
Thanks
Old May 20, 2007 | 03:06 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Panic Alarm
but you may be best off to just disconnect it. something electronic. most likely there is a leadwire going from the sensorto a relay to activate it. my guess might be a bad relay. what year is it? they gen specific sections have some pretty knowledgable folks that may be able to better assist you.
Old May 20, 2007 | 12:05 PM
gearue's Avatar
gearue
I could unhook the horn but the lights also flash when the panic alarm is activated.
Old May 20, 2007 | 09:15 PM
flamingpinhead
Section Moderator
i was actually referring to the alarm itself. maybe someone has a manual with the wiring diagram, so you can unhook the leadwire that activates the alarm
Old May 20, 2007 | 09:54 PM
gearue's Avatar
gearue
That makes good sense,now I need to locate a wiring diagram and get the alarm problem taken care of.
Thanks for clearing that up.
Old May 21, 2007 | 10:54 PM
gearue's Avatar
gearue
I need a wiring diagram for 2000 Neon.Having panic alarm going off all hours day and night.
Thanks
Old May 25, 2007 | 12:09 AM
Andpto's Avatar
Andpto
get a haynes manual it has all the wiring diagrams
Old May 26, 2007 | 11:44 PM
gearue's Avatar
gearue
Thanks for your reply.It's going to the shop on Tuesday.
