Prothane Kit Numbers just in case
Old May 22, 2007 | 02:39 AM
ewetho's Avatar
ewetho
Default Prothane Kit Numbers just in case
Chrysler Dodge/Plymouth/Neon, PT Cruiser
BUMP STOPS
(PT Cruiser)
01-06 Rear Bump Stop Kit 4-1301
COIL SPRING ISOLATORS
(PT Cruiser)
01-06 Front Coil Spring Isolator Kit, Lower 4-1704
01-06 Rear Coil Spring Isolator Kit, Upper & Lower 4-1705
CONTROL ARM BUSHINGS, FRONT
(Neon, SRT-4)
95-99 Front C-Arm Bushing Kit 4-209
00-06 Front C-Arm Bushing Kit 4-214
(PT Cruiser)
01-06 Front C-Arm Bushing Kit 4-214
CONTROL ARM BUSHINGS, REAR
(Neon, SRT-4)
95-99 Rear C-Arm Bushing Kit 4-301
00-06 Rear Trailing Arm Bushing Kit 4-304
(PT Cruiser)
01-06 Rear Trailing Arm Bushing Kit 4-302
01-06 Rear Watts Linkage Bushing Kit 4-303
END LINK BUSHINGS, Front & Rear
(Neon)
95-99 Front End Link Kit 4-401
95-99 Rear End Link Kit (sport package only) 4-402
(Neon, SRT-4)
00-06 Front End Link Kit 4-401
00-06 Rear End Link Kit 19-413
(PT Cruiser)
01-06 Front End Link Kit 4-401
01-06 Rear End Link Kit 4-403
MOTOR MOUNT INSERTS
(Neon-SOHC, DOHC & SRT-4)
95-99 Engine Mount Insert Kit, Front 4-501
95-99 Engine Mount Insert Kit, Right 4-502
95-99 Transmission Mount Insert Kit, Left 4-503
95-99 All 3 Mounts, Kit 4-1901
95-99 All 3 Mounts, Kit (Softer Street Style) 4-1902
00-06 Upper & Lower Mount Insert Kit (Race) 4-1905
00-06 Upper & Lower Mount Insert Kit (Street) 4-1906
SHIFTER BUSHINGS
(Neon)
95-06 Shifter Bushing Kit 4-1605
03-06 SRT-4 Shifter Bushing Kit 4-1606
STRUT ROD BUSHINGS
(Neon, SRT-4)
95-99 Rear Strut Rod Bushing Kit 4-1204
00-06 Rear Strut Rod Bushing Kit 4-1206
SWAY BAR BUSHINGS. Front & Rear
(Neon, SRT-4)
95-06 Front Sway Bar Bushing Kit, 20mm Bar 4-1118
95-99 Front Sway Bar Bushing Kit, 22mm Bar 4-1119
00-06 Front Sway Bar Bushing Kit, 24mm Bar 4-1120
95-99 Rear Sway Bar Bushing Kit, 16mm Bar 4-1111 *(Sport Package only)
00-06 Rear Sway Bar Bushing Kit, 12mm Bar 4-1130
00-06 Rear Sway Bar Bushing Kit, 14mm Bar 4-1131
00-06 Rear Sway Bar Bushing Kit, 17mm Bar 4-1137
(PT Cruiser)
01-06 Front Sway Bar Bushing Kit, 22mm Bar 4-1119
01-06 Front Sway Bar Bushing Kit, 24mm Bar 4-1120 *(Touring Edition)
01-06 Rear Sway Bar Bushing Kit, 18mm 4-1136
TIE ROD BOOTS
(Neon)
95-99 Tie Rod Boot Kit (2) 19-1711
TOTAL KITS
(Neon)
95-99 Total Kit (Includes Sport Package) 4-2002
00-06 Total Kit (Neon, SRT-4) 4-2007
(PT Cruiser)
01-06 Total Kit (Includes Touring Edition) 4-2006
