braking system
Old Sep 18, 2004 | 09:21 PM
exotic4's Avatar
exotic4
Default braking system
I have a 95 neon and a 98 neon. The 98 is a 5 lug and the 95 is a 4 lug. I want to switch the brake systems on these so the 95 will be a 5 lug. Does anyone have any suggestions about parts that need to be replaced or any hints to make this job a little easier? [&:]
Old Sep 19, 2004 | 12:13 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Default RE: braking system
You are going to need the hubs, spindles possibly control arms. You are definitely going to need the brakes fromt he 5 lug as I'm sure the 5 and 4 lugs were different. I'm sure there are other things but that's all I can think of right now.
Old Apr 15, 2007 | 04:20 PM
Flash_Gordon2392's Avatar
Flash_Gordon2392
Hay,how are you doing man?I have a few questions on what you are doing to your brake system?Are planning to changeyour rear from drum to disk? If so because I am tring to do the same with mine.There is a company in Mooresvile,North Carolina named Master Power Brakes.You can give them a call at 1-888-356-7297 or go to www.mpbrakes.com and also if that doesnt work,try to call your local Dodge Dealership for some input.
