Coolant pouring out from under engine
Old Jun 4, 2007 | 12:54 PM
blacktortoise's Avatar
blacktortoise
Default Coolant pouring out from under engine
I turned the car on this morning. It ran for about 5 minutes then started smoking. Coolant started running out from under the engine. The coolant waspouring from the back of the engine on the passengers side. Any ideas. Waterpump maybe?
Thanks for the Help!
Old Jun 4, 2007 | 02:24 PM
spudsterier's Avatar
spudsterier
Default RE: Coolant pouring out from under engine
sounds like the water pump went out[&:]
Old Jun 7, 2007 | 01:37 AM
master tech's Avatar
master tech
Site Moderator & Tech
Pressure test the cooling system. The lower hose clamp could be broken or water pump.
