Soft Brakes/brakes go almost to the floor
ive searched the forums, and from what ive seen is that bleeding all 4 brakes, replacing the master cylinder, or replacing the brake booster is what is recommended to fix this, so i was wondering if there are some other things you guys could suggest to me to fix this problem, it kind of scares me, because i feel like my front brakes do not work.
thanks.
thanks.
RE: Soft Brakes/brakes go almost to the floor
yea, thnx for all the help, i guess, i found out what the problem was.
in my rear right drum, a peice of the brake shoe broke off and punctured the brake hydraulic thing in the drum brake, or whatever you want to call it.
well, that caused a slow leak and made my pedal soft, so that took a good 5 hrs to fix and get the parts for....
