2000 neon thermostat location
Old Jul 12, 2007 | 01:14 PM
jlaum3's Avatar
jlaum3
Default 2000 neon thermostat location
does anyone know where the thermostat is located on a 2000 neon?
Old Jul 12, 2007 | 01:34 PM
03neonRT's Avatar
03neonRT
Default RE: 2000 neon thermostat location
The thermostat housing is on the front left side of the cylinder head where the radiator piping enters the head. You remove two screws and the housing will come off the head, then the thermostat is right there...
Old Jul 12, 2007 | 01:47 PM
jlaum3's Avatar
jlaum3
Will it spill a lot of coolant after I loosen those two bolts? And is the thermostat just a snap on?
Old Jul 12, 2007 | 03:11 PM
03neonRT's Avatar
03neonRT
It wont spill a lot of coolant, but you should put a towel or something underneath the thermostat housing to catch any coolant that does come out...the thermostat just sits in the housing, there arent any clamps, bolts, or anything holding it in. Just a single groove so you know its positioned inside the housing correctly.
