Im missing something !!! Help me !!
Old Oct 16, 2004 | 12:18 AM
casper's Avatar
casper
Default RE: Im missing something !!! Help me !!
yeah NOS is just a brand like Band-aid and Kleenex. But its just the name used to refer to a product.
Old Oct 16, 2004 | 07:38 AM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: tyson724
My car has lots of mods. but im still not happy!! I need more Power !!
This is what i have in my car, please tell me what i need to make more power :
1. Magnum ported head with stage 3 porting
2. Crane cam #14
3. Crane valve springs+retainers
4. 60mm Throttle body
5. Afx race computer
6. Screaming Demon coil
7. Ice Man cold air intake
8. Optimun Battery
9. Stainless Steel Header
10. Race Cat Convertor
11. Borla Exhaust muffler
12. B+M short throw shifter
13. Booger shift bushings
14. Magnecor spark plug wires
15. Unorthdox Racing underdrive pulley16. Motor mount inserts
WHAT IS MISSING ??
[IMG]local://upfiles/4785/E14D8F1221CA47018A8B6B2182E79874.jpg[/IMG]
First off you will want to get the Indy intake manifold, it will give you a huge gain with your current mods, it is good for 30+ WHP gain on a 2.0L DOHC with just a CAI and PCM. Strut tower braces would help stiffen it up around the curves. Unorthodox lightweight cam gears. Engine grounding kit. Higher flow fuel injectors. Polyurethane bushings and a coil over kit. Cryo2 intake cooler. Moroso aluminum oil pan, it holds an extra quart and has a windage tray and trap doors to hold oil around the pick up tube. MSD dis-4 ignition box. The only things left that I can think of are to lighten the car and stiffen the chassis, tear the motor apart and put in longer lighter rods and lighter higher compression pistons and/or turbocharge and intercool it.
Old Oct 16, 2004 | 03:19 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
You don't really want the Indy. The gains are minimal and you need to be producing a hell of a lot of power to see any real difference. Most guys I know who have the Indy do not like it. I think what Road Runner is trying to tell you to get is the DIS 2 which might be a good investment for you. The DIS 4 is for 6 and 8 cylinder cars and won't work on your car. You won't see any gain frmot he grounding kit, unless of course you've got a lot of bad grounds already and have a stereo system. But as for performance gains there are none. You shouldn't need higher flow fuel injectors either but you can install them. YOu might see a little gain off of them but I wouldn't be surprised if they make the car run richer than normal. Neons run rich regardless.
The bushings are definitely a good buy as are the coil overs Leda makes a real nice set of coil-overs for Neons. I have a Morosso oil pan and it is nice. I've wondered about the Cryo2 intake cooler it sounds like a good idea but I don't know of anyone who has one.
Keep in mind, if you do go turbo you may not be able to use some of the bolt on stuff so keep that in the back of your mind as you build the car.
Old Oct 17, 2004 | 10:40 PM
tyson724's Avatar
tyson724
the hood i have on the car is real fiberglass with working air scoops. i dont know the dyno #s
so i quess i need a turbo ? there so expensive !!!
Old Oct 17, 2004 | 10:45 PM
Cr@zy Squ33
You don't NEED a turbo. It's just something to think about while you are building your car.
